TwinTurbo.NET: Nissan 300ZX forum - Yep. Driving me crazy. Going to try reseating the ECU
ctheobal
on May 31, 2026 at 8:49 PM
So they're good... The issue isn't the injectors.
posted by Polishzx
on May 31, 2026 at 03:03 PM
Connector
Injectors 1 and 2 not firing
ctheobal
19:29:26 05/29/26
Ohm test the new injectors just to be sure
Polishzx
17:37:15 05/30/26
Thanks! Did use dielectric grease. Did not seem like I used
ctheobal
20:59:17 05/30/26
Yes there is
Polishzx
22:45:13 05/30/26
Thanks Eric (n/m)
ctheobal
22:57:51 05/30/26
Injectors 1&2 show 11.2 ohms same as injector 3. (n/m)
ctheobal
12:17:57 05/31/26
Polishzx
15:03:43 05/31/26
Yep. Driving me crazy. Going to try reseating the ECU -
ctheobal
20:49:01 05/31/26
Double check your Efi harness is seated in the ECU
itsa300zx
11:39:49 05/31/26
Will do, thank you (n/m)
ctheobal
12:19:10 05/31/26
Re: Injectors 1 and 2 not firing
Zxpress
08:04:17 06/01/26
Thanks John I will try that (n/m)
ctheobal
15:30:24 06/01/26
